Need a key made asap
Old Feb 18, 2016 | 08:10 AM
Germanwerks's Avatar
Default Need a key made asap
So apparently my lil girl got ahold of my key for my disco 2 and it can't be found in the house anywhere. Besides the dealer is there anywhere to get a key made at that isnt going to cost my a million dollars? Lol
Old Feb 18, 2016 | 08:27 AM
abran's Avatar
A locksmith could make one from "feel" or you are supposed to be able to get a serial number code from the dealer that allows a locksmith to reference a database to cut a new one.
Or as you mentioned, go to the dealer and pay around $250.
For the time being, use a pump bladder thing in the window frame and a long metal stick to push the unlock button in the dash. Then remove the ignition and turn the switch at the back to start.
Old Feb 18, 2016 | 08:49 AM
wont the immobilizer be activated if I did this?
Old Feb 18, 2016 | 11:54 AM
abran's Avatar
Even though I answered him on text, no. Central unlocking deactivates the alarm.
Old Feb 18, 2016 | 12:25 PM
CoMo's Avatar
I've had one cut from code before. Call your nearest Land Rover service department from a locksmith and give them your VIN number. They can give the locksmith a code for the automated cutter. It cost me $5. I just don't have a keyfob anymore so have to manually lock and unlock. If your nearest dealership won't do it, call around. It was the one in Orlando, FL that gave it to me.
Old Feb 19, 2016 | 03:53 PM
BS50MGSXR's Avatar
did the discovery 2 ever have a separate door key from the ignition? or was the ignition key the only key that did both doors and start the car?
Old Feb 19, 2016 | 04:57 PM
number9's Avatar
Doubt it.
OM:
KEYS AND HANDSETS
You have been supplied with two remote
handsets with integral keys which operate all
locks.
To unlock the steering column
Insert the key FULLY and turn the starter switch
to position ‘I’.
Old Feb 19, 2016 | 05:53 PM
drowssap's Avatar
One key
Originally Posted by number9
Doubt it.
OM:
ProRiderRoadKing
Jul 27, 2013 09:27 PM
aarongregor
Nov 21, 2012 04:08 PM
Brad S1
Jun 28, 2006 03:25 PM
TATZOO
Aug 28, 2005 10:16 PM
Sara@academy
Aug 2, 2005 12:41 AM
