Can someone look at my abs amigo results and help me figure out where to begin?
I haven't used the ABS Amigo, but I've dealt with ABS stuff using the Hawkeye.
It's hard to say for certain what this points to, but my first step would be to test the pump relay, which I believe is inside the engine compartment fuse box. The wheel speed sensor faults could be caused by a bad relay. Or you could have a bad wheel speed sensor. It'd be easy to eliminate the relay, though, so why not do that first?
seaosrover
10-23-2010 01:48 AM
camgkh
05-17-2010 12:42 PM
