Can someone look at my abs amigo results and help me figure out where to begin?
Old Nov 2, 2016 | 10:51 PM
Manbeer's Avatar
Default Can someone look at my abs amigo results and help me figure out where to begin?
Just ran a quick check on my 99 with the ABS amigo and these are the codes that came up
​​​​​I'm new to this system so I wasn't sure of where to start
Thanks in advance,
Chris
Old Nov 3, 2016 | 07:29 AM
batard's Avatar
I haven't used the ABS Amigo, but I've dealt with ABS stuff using the Hawkeye.
It's hard to say for certain what this points to, but my first step would be to test the pump relay, which I believe is inside the engine compartment fuse box. The wheel speed sensor faults could be caused by a bad relay. Or you could have a bad wheel speed sensor. It'd be easy to eliminate the relay, though, so why not do that first?
Old Nov 3, 2016 | 11:24 PM
Manbeer's Avatar
Thank you, I swapped the relay with one from my other d2 and it seems to have solved the problem for now. I love easy fixes, was really hoping it wasn't a sensor
Old Nov 5, 2016 | 09:51 AM
Charlie_V's Avatar
Great resolution. Good going (and to Batard too)!
Old Nov 6, 2016 | 12:24 PM
OffroadFrance's Avatar
Nice logic Batard it's probably saved the guy a bundle of dough and a couple of dirty hours work.
microbc
Feb 28, 2013 02:47 PM
seaosrover
Oct 23, 2010 01:48 AM
bosshogt
Sep 18, 2010 01:16 PM
palabratic
Dec 5, 2009 07:52 PM
