Can you replace core (freeze) plugs while the motor is installed.
Old Mar 8, 2011 | 08:32 PM
mtfife's Avatar
Default Can you replace core (freeze) plugs while the motor is installed.
It looks to me like the freeze plugs can be replaced while a 2000 Disco engine is intact by removing the starter and engine mounts. Am I correct, or does it have to come out? If it can be done, does anyone have suggestions for getting the plugs out which are not protruding enough to get pliers on them?
Thanks-
mtfife
Old Mar 8, 2011 | 08:43 PM
Yes it can be done, it wont be easy, but it can be done.
Old Mar 8, 2011 | 08:55 PM
mtfife's Avatar
I have seen a punch bar used to twist them out on an engine already removed from the vehicle. I will only need to twist out 2 of the 6. The rest have expanded out enough to get with pliers. Are you familiar with a good technique to get the others out since there is not enough room to use the punch bar?
Old Mar 8, 2011 | 09:16 PM
I have no suggestions for you, sorry.
Maybe drill a hole in the middle and thread in a bolt?
Old Mar 9, 2011 | 05:27 AM
mtfife's Avatar
Thanks Spike- Do you know if the Rover blocks have core plugs at the front and back of the block as many other motors do? I have only seen a mention of the 3 on each side including the rave manuals.
Old Mar 9, 2011 | 05:40 AM
Bundu's Avatar
Banned
There are at the back, 2 if memory serves me well.
How the heck did they expand out? Did you freeze your block or something?
Old Mar 9, 2011 | 06:43 AM
mtfife's Avatar
Yes -
I had the engine torn down in my driveway for leaking intake gasket and radiator. Took it down to head gaskets and because of the leak and adding water to keep it cool, the antifreeze was out of ratio. While all the hoses were off and most water was gone, I had forgotten to drain the block, and bam, an ice storm hit in texas for about 4 days. Haven't seen that in over 25 years. Anyway most of the plugs popped out and I am hoping they drained the bulk of the H2O. I can't see any visible craks on outside, and I am praying there is no internal damage. Guess I will know when I fire it up.
Old Mar 9, 2011 | 07:57 AM
Bundu's Avatar
Banned
Ouch....
robersonb
May 31, 2023 10:59 AM
renfield
Aug 2, 2011 02:59 PM
Hashbrown
Jan 2, 2011 10:37 AM
EL GALLO
Nov 7, 2007 08:05 PM
