Can you use 03-04 front grill with 01 style glass headlights?
Old Apr 3, 2020 | 06:36 PM
Boostle's Avatar
Default Can you use 03-04 front grill with 01 style glass headlights?
Silly question but has anyone done this? Is it possible? I feel like I've seen it done on someone's truck but can't find a picture.
Thanks.
Old Apr 3, 2020 | 07:38 PM
Extinct's Avatar
Yes, look up my 2002 Disco for sale ad, it has the newer grille on it.
Old Apr 3, 2020 | 07:40 PM
Boostle's Avatar
Thank you anything I need to know when making the swap ?
Old Apr 4, 2020 | 05:24 AM
Extinct's Avatar
No, obviously not as good a fit as the proper grille, small gaps in the corners, but otherwise fine.
Old Apr 4, 2020 | 09:58 AM
Best4x4's Avatar
Yes any 94-04 Grill can be swapped around but small mods are necessary.
I have an 02 D2 Kalahari with an 03-04 Grill, I installed a TF front winch bumper and with the original 99-02 grill it would have required me to cut off nearly 1inch off the bottom (original Saudi Grill) which I was not going to do! The 03-04 grill worked out perfectly as it isn't as tall (due to the 03-04 front bumper design). That allowed me to install a Warn Winch without chopping up the grill and it also meant I didn't have to cut it to install the TF front bumper. The only thing you need to do is shorten the front corner bezels (ones that sit under a 99-02 D2 headlight). I just used a hacksaw and it was super simple. Then I made 2 little metal brackets to support the front corner bezels.
My 99 D2 is also now sporting an 03-04 grill as the original fell to pieces and I did the same procedure as mentioned above. The 03-04 Grill is made out of a much more durable plastic vs 94-02 units that reminded me more of egg shells.
Old Apr 4, 2020 | 07:15 PM
Boostle's Avatar
Thanks for the pictures and explanation!
Old Apr 5, 2020 | 09:35 AM
mln01's Avatar
My truck has the same setup as Best4x4's Kalahari, but Best, how did you attach the bezels to the brackets you fabricated without putting a screw through their inboard ends?
Old Apr 5, 2020 | 11:26 AM
Best4x4's Avatar
I used a pair of those sticky tape backed zip tie holders on the Kalahari. On the 99 I just drilled 2 holes & used 2 stainless steel bolts. The TF bumper sits directly under the bezel so it just needed to be held front to back. On the 99 with an ARB I needed to make sure it was good at fully supporting the bezel weight so I used a bolt. Looks fine IMHO.
Disco Aaron
Feb 11, 2020 04:03 PM
Brandon318
Oct 12, 2019 10:04 AM
Nunezjoel13
Jan 28, 2018 06:31 PM
Dane!
Apr 6, 2014 02:39 PM
Dane!
Apr 1, 2014 10:57 AM
