Cannibal V8 - Anyone with experience with them
Most likely need to replace my engine. I've been reading about Cannibal V8's redesign of some of the known weaker components in the Rover V8...
CANNiBALV8
I've read some negative things about CarCannibal...
Land Rover Discovery II Used Engine Auto Parts : Rover Body Parts
which is where I linked to Cannibal V8. Supposedly they are two separate companies.
Before I part with over $5000 for a remanufactured motor, I'd like to hear from anyone who has purchased a motor from them about your experience.
CANNiBALV8
you might want to compare with this company they have sold a few on this site in the last year and they come with a 3-year 36000 warrenty;
Land Rover Engine Remanufactured 4 6 Long Block w Flanged Cylinder Liners | eBay
I just spoke to both companies in the last two days and the prices quoted were within $200 of each other. What am I missing? Please expound on the horror stories, what are the problems with the CannibalV8. The reason I ask is the shop my truck is sitting at is a "partner" with them and so before I go pissing them off by possibly sending them an engine from another company, I'd just like a bit more info.
Thanks!
Thanks!
If your trusted indy mechanic is behind them and there is no large price difference then go with the indy plan. I'd point out the following:
1. HG installs fail early if part of gasket folded over, or heads were not checked for flatness, or machined improperly (Bubba and the belt sander). The heads have a limit as to how much material can be removed, so the machine shop might not be able to correct a problem. The spec is attached. So you might need head gaskets and some new or recycled heads. The flatness spec is .002 inch, or about 1/2 the thickness of printer paper.
2. Most Rovers are in the boneyard because of overheating, so a used engine which might be $200 will likely need HG as a minimum, and liners may still slip or need to be pinned. With the overheating you have suffered you may want to have your liners pinned anyway. Review https://landroverforums.com/forum/di...ictures-56419/ for what is involved.
3. The kind of money this will cost (replace engine) is on the order of what you could pay for a used Discovery. Hopefully you just nead a good HG job. And a new 180F thermostat, your existing stat may have or get trash in it from all the work.
4. The block pressure test is performed with the heads off, and uses shop air pressure. This is to detect cracks in the block. And avoid rebuilding a block with problems.
Search this forum...there is a link to a local news clip about Cannibal selling off people's rides who sent them in for engine work. That was a while ago though (like early 00's) and haven't heard much negativity since. I researched them, D&D Fab, Great Plains and JE Robinson for about 3 months including website reviews and several phone conversations with each. In the end I went with Great Plains (engine due 18 Apr). I'll be happy to expound if you wish on why I chose Great Plains. If you can wait, I'll be able to give you first-hand info/pics of their product and how the install went.
