Cannot shift from 4H to 4L
Old Sep 8, 2018 | 02:05 AM
ReconDoc83's Avatar
Default Cannot shift from 4H to 4L
2000 Disco2 V8 SD:
I am a new LR owner...so it is quite possible that I am a complete idiot when it comes to some of the questions I am going to be asking...so please bare that in mind when responding.
I have followed the instructions in the owners manual; I have tried the “alternative” process in the owners manual.
I can’t get the damned thing to budge from 4H; won’t move at all....tips, tricks, something I’m not doing right?
thanks
Doc
Old Sep 8, 2018 | 05:08 AM
naivedisco2's Avatar
Odds are good that your shift interlock solenoid is dead / jammed from not being used for the last 18 years. It's a huge pain, but you can get to it by removing your entire center console area. There are write-ups around somewhere that detail the process. That's what I had to do. Supposedly a handful of people were able to remove / replace it from below, but I can't see how that's possible, as the parts are on TOP of the transfer case, covered up with wires and cables.
You could also have a jammed up shift linkage, especially if your Disco has rust or corrosion all over. You might be able to try to lubricate it from below as a first attempt. Good luck, welcome to Land Rovers!!! I started with a Disco 2-3 years ago, now my wife drives a P38 and I'm working on a Range Rover Classic as well!
Old Sep 8, 2018 | 07:38 PM
ReconDoc83's Avatar
Are there any pictures of the process or the solenoid so I know what I am looking for?
Old Sep 9, 2018 | 02:40 PM
Richard Gallant's Avatar
Well you can lie underneath on the passenger side and lookup near the back of the transmission, you can see the cable from there. If you get a can of spray lubricant you can hit the area of the cable and nipple, you might get lucky and get it move. If you do repeat the process 4 or 5 times and then shift up and down a bunch time s to get things freed up
Old Sep 9, 2018 | 03:46 PM
OffroadFrance's Avatar
It sounds familiar as the low gear is rarely used, the mechanism is probably rusted solid. There is a very slow procedure for changing into the low gear transfer box. Initially spray the mechanism with penetrating oil and leave for 24 hours and then respray again and wait for a few hours then try changing gear whilst moving very slowly, say 5-8mph in N neutral autobox.
Old Sep 9, 2018 | 06:41 PM
Best4x4's Avatar
On a 2000 D2 the interlock solenoid is mounted on the top of the Transfer Case just behind the E-Brake Drum assembly. If you remove the E-Brake assembly and you use a short 1/4 ratchet with a an 8mm socket you can remove the 4 screws that hold the interlock solenoid into place. You will also need to remove the 10mm bolt that secures the Hi/Low cable to the TC. Then you can simply lift the interlock solenoid up and out after you unplug it.
If you don’t have a rusty D2 I doubt it’s the cable. It’s most likely the interlock solenoid. Since you have a 2000 the chances are good you have the CDL nipple so I’d invest in an 04 CDL linkage, and while you were installing it you could remove the interlock solenoid from the TC. The 03-04 4hi/N/4lo assemblies have the interlock solenoid mounted on the assembly itself vs on the TC. Then just make a little blank plate out of some steel or aluminum and RTV it and mount it in place of the original interlock solenoid. Then just plug in the 03-04 interlock solenoid in and your done.
PrinceDisco
Oct 12, 2017 01:49 PM
dev99disco
Jan 25, 2016 08:00 PM
DROVER1984
Dec 12, 2012 09:29 AM
Hirley Issayana Diaz
Mar 22, 2012 04:32 PM
louiev
May 30, 2010 09:40 PM
