Cant find std size rod bearings
Old May 23, 2020 | 08:41 PM
mollusc's Avatar
I think these are the ones i installed in my engine a couple of weeks ago:
https://lucky8llc.com/collections/di...ederal-mogul-2
Old May 24, 2020 | 10:01 AM
Sixpack577's Avatar
You Need to measure the crank journals first.
The journals should be stock diameter, which means you need stock size bearings.
Oversize bearings will Not fit a stock crank, as the oversize bearings are thicker to compensate for the worn material the lathe cut off the crank...which would then require thicker bearings.
You only need oversize bearings if the crank journals are worn and have been/need to be machined/turned to a smaller I.D to smooth the journal surfaces.
Old May 24, 2020 | 10:39 AM
Best4x4's Avatar
Yeah the last set I bought came from Lucky8's Ebay listing.
zuke
Jul 15, 2019 07:43 PM
Sixpack577
Apr 13, 2018 04:39 AM
LRD2&ME
Aug 24, 2016 10:21 AM
Grlica
May 1, 2013 06:13 PM
vandev
Apr 17, 2010 07:04 AM
