Cant finish propeller shaft rebuild
I was in the process of completing the front propeller shaft rebuild when the very last snap ring will not go on due u-joint not seating in far enough.
Not really sure how it happened, but it looks like I might have to take it all apart. It is the first yoke nearest the input flange. Ecrything else went fine.
Any suggestions?
Any suggestions?
Thanks I did that one a few months ago.
Right after I bought it, I noticed a sound and found out that one of the bolts came loose and tore up both flanges and the rotoflex. The old propeller spline shaft had siezed up as well. I got a used shaft and rebuilt it. In the process I ended up with a used differential that I never used. It has 60,000 on it and I would like to sell it.
Thanks for the tips!
mcgyver210
01-30-2011 09:03 PM
jenniemcl
01-15-2011 07:10 AM
