Cant finish propeller shaft rebuild
Old Feb 4, 2012 | 07:25 PM
4x4ron's Avatar
Default Cant finish propeller shaft rebuild
I was in the process of completing the front propeller shaft rebuild when the very last snap ring will not go on due u-joint not seating in far enough.
Not really sure how it happened, but it looks like I might have to take it all apart. It is the first yoke nearest the input flange. Ecrything else went fine.
Any suggestions?
Old Feb 4, 2012 | 08:46 PM
Either something wrong inside U joint, or some trash you have not seen, or Kattywhompus alignment of parts. Disassemble to be sure.
Old Feb 5, 2012 | 09:53 AM
4x4ron's Avatar
Thanks for the reply. A little more persistence and I got it to work. Everything is back in and ready for a test drive this morning.
Overall it was a pretty painless operation.
Old Feb 5, 2012 | 10:02 AM
Great - and you greased them and the ones on the rear drive shaft and the slip/slide part of the shaft.
Old Feb 5, 2012 | 05:19 PM
4x4ron's Avatar
Yes I didn't spare any grease. The old U joints where in pretty good shape for the number of miles. The splined shaft was really dry. I cleaned it up and greased'er down good.
Now I have rebuilt both shafts. Thanks for your input!
Old Feb 5, 2012 | 07:54 PM
Take a good look at the rubber coupler at the end of the rear shaft. Eventually will need to replace.
Old Feb 6, 2012 | 04:20 PM
4x4ron's Avatar
Thanks I did that one a few months ago.
Right after I bought it, I noticed a sound and found out that one of the bolts came loose and tore up both flanges and the rotoflex. The old propeller spline shaft had siezed up as well. I got a used shaft and rebuilt it. In the process I ended up with a used differential that I never used. It has 60,000 on it and I would like to sell it.
Thanks for the tips!
wrongway1
Mar 8, 2015 10:52 PM
grandkodiak
Mar 3, 2011 10:02 PM
mcgyver210
Jan 30, 2011 09:03 PM
jenniemcl
Jan 15, 2011 07:10 AM
imike1007
Jul 20, 2010 06:44 PM
