Can't get oil pan off
Old 07-17-2017, 08:49 PM
No Doubt's Avatar
If you already removed the 8 bolts on the rectangular cross-member frame-support bar to remove it, then you just need to turn the steering wheel to opposite lock to give yourself enough room for the pan to clear the round front sway bar.
*If it still doesn't clear it then you may need to jack up the front a few inches to raise the suspension.
Old 07-17-2017, 08:59 PM
Disco2SE's Avatar
Question
I heard you can remove the pan without removing the cross member by just jacking the truck up high enough, true?
Old 07-17-2017, 09:06 PM
No Doubt's Avatar
I doubt it, but maybe someone with a 6" lifted Disco could jack it up high enough for the pan to come out the front?? Even that I doubt, but I haven't tested it so who knows.
...but, that rectangular frame support cross-bar won't raise or lower or change its position vs your oil pan no matter how you jack or lift your Disco(?), so every normal Disco owner is going to have to unbolt it, which is easy, just 8 bolts that won't give you any trouble. They won't be rusted or anything (though come to think of it, I hit all of my bolts with penetrating oil about an hour before I did my oil pan removal this morning).
Then the oil pan twists plus comes down and out the back.
Jacking up your Disco *will* help clear the round sway bar, though.
Old 07-17-2017, 11:20 PM
abran's Avatar
OH THOSE RECESSED NUTS....I feel like a complete douchbag .....my apologies to the entire forum.
Next time I need to read .....carefully.
Now how to I wiggle this pan out of the bottom of the truck
Thst is why I was specifying vertical! Glad you got it.
abran
02-08-2017 10:55 PM
Justmejr04
07-13-2016 08:17 PM
erick846
12-01-2015 11:19 AM
Frank4
09-19-2010 06:23 PM
audiS4S6
04-23-2010 08:24 AM
Quick Reply: Can't get oil pan off
