Transmission Fluid Q?
Old Jul 17, 2017 | 03:54 PM
LR03NJ's Avatar
Default Transmission Fluid Q?
Hiw many galloms or liters to fill transmission? Thanks
Old Jul 17, 2017 | 04:01 PM
KingKoopa's Avatar
Until it comes out of the fill hole while idling. Think I used a little over a gallon, maybe 5 quarts.
Old Jul 17, 2017 | 04:19 PM
LR03NJ's Avatar
Hi King, bit strange. My 2nd time and still i have half a quart left it pouring out the hole already. I think its full.
Thanks for replying fast
Old Jul 17, 2017 | 04:30 PM
KingKoopa's Avatar
Is the vehicle running? I think you are fine, now that I think about it, the tube on my hand pump isn't long enough to reach the bottom of the gallon jugs, so I think 3.5 to 4.0 quarts is probably closer to accurate.
Old Jul 18, 2017 | 04:44 AM
OffroadFrance's Avatar
Keep your foot on the brake with the parking brake on and exercise the gear shifter slowly from P through to 1 and back to P a few times. This helps fill the pump, TQ and valve block adequately and then top up the ATF with engine running and repeat the shifter exercise.
Athana
Jun 8, 2019 10:23 AM
Rolltop
May 5, 2014 09:17 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
LRScott
Mar 4, 2009 08:39 AM
ferrelltodd
Aug 9, 2005 10:11 PM
