Can't get rid of waterfall
I have a 1998 D1. The vehicle was overheating and had a waterfall sound/no heat at idle. I followed the procedure of filling the overflow tank up while cold and opening purge valve in radiator. I capped the purge valve off as soon as fluid started to come out and filled the expansion tank full. Now, I have heat at idle, but still a slight swishing noise under the dash. I even tried this procedure with the front end jacked up, but to no avail. Any suggestions?
msn619
23
04-26-2014 01:59 PM
