Can't get rid of waterfall
Old Mar 15, 2010 | 07:42 AM
bantham1's Avatar
Default Can't get rid of waterfall
I have a 1998 D1. The vehicle was overheating and had a waterfall sound/no heat at idle. I followed the procedure of filling the overflow tank up while cold and opening purge valve in radiator. I capped the purge valve off as soon as fluid started to come out and filled the expansion tank full. Now, I have heat at idle, but still a slight swishing noise under the dash. I even tried this procedure with the front end jacked up, but to no avail. Any suggestions?
Old Mar 15, 2010 | 08:22 AM
tornado_735's Avatar
Do it again, there's still air in the system. Is there a purge valve near the hoses that run to the heater core?
Old Mar 15, 2010 | 09:12 AM
If you still can't stop the noise, don't drive it and send me your tele number.
bantham1's Avatar
No, there is not purge valve. I have done this 5 times. I have also squeezed the upper hose and this did not work.
Old Mar 15, 2010 | 09:15 AM
So, send me your number and I'll walk you thru the fix.
msn619
23
Apr 26, 2014 01:59 PM
rovingmad
Detailing
14
Oct 28, 2013 11:01 AM
slanginsanjuan
Off Topic
Feb 11, 2013 08:14 AM
03discoman
Sep 2, 2009 11:44 PM
GadgetRick
Jun 24, 2005 12:33 AM
