Can't open rear door
Old Nov 19, 2010 | 10:12 AM
barsa's Avatar
Default Can't open rear door
It locks and unlocks fine, but neither the inside or outside door pull will open the door. My guess is that a lever either broke or popped off.
I haven't tried any more to get it open, any ideas or inside secrets to getting it open are well appreciated.
Old Nov 19, 2010 | 10:25 AM
pilsner's Avatar
On the rear handle above the license plate is a land rover emblem. pop it off and spray some WD-40 in there. work the handle a few times and PRESTO - working door. 30 second fix.
Old Nov 19, 2010 | 10:31 AM
hilltoppersx's Avatar
if you only have to work it for 30 seconds consider yourself lucky. i use a silocne lubricant rather than wd-40.
Old Nov 19, 2010 | 10:56 AM
barsa's Avatar
Thanks, I'll try that tonight and report back.
Old Nov 20, 2010 | 03:58 PM
barsa's Avatar
I sprayed my motorcycle chain oil on the handle hinges and the rod that goes into the tailgate, I worked it for a good 15 min or so and it finally opened. Now it opens every once in a while but getting better.
ccarman12
Oct 18, 2013 11:51 AM
ToddD
Jun 24, 2012 09:14 AM
tnhotrod
Jun 28, 2010 06:54 PM
