Car stalled today, now pulling check engines
Hello! I've got an 03 Disco with 134k miles. Driving today, and it stalled in traffic. It was about 85 degrees out and shut off. Coolant temps were about 185-190 degrees. It started right back up afterwards, but pulled these codes:
Stored Codes
P1884 (Unknown)
P0102 (Mass or Volume Air Flow "A" Circuit Low)
P0340 (Camshaft Position Sensor "A" Circuit Bank 1 or Single Sensor
P1451 (Unknown)
P0414 (SAI System Switching Valve "A" Circuit Shorted)
P1482 (Unknown)
P0445 (Evap Emission System Purge Control Valve Circuit Shorted)
P0448 (Evap Emission System Vent Control Circuit Shorted)
P0134 (O2 Sensor Circuit No Activity Detected Bank 1 Sensor 1)
P0154 (02 Sensor Circuit No Activity Detected Bank 2 Sensor 1)
P0135 (O2 Sensor Heater Circuit Bank 1 Sensor 1)
P0155 (O2 Sensor Heater Circuit Bank 2 Sensor 1)
P0141 (O2 Sensor Heater Circuit Bank 1 Sensor 2)
P0161 (O2 Sensor Heater Circuit Bank 2 Sensor 2)
Pending Codes
P1451 (Unknown)
I cleared the codes once, and they just came back up again. Those codes are after the first clear, so they should all be fresh. Is it my MAF sensor? Or do I have to replace all of that ****? I'm a little frustrated as it's not even 72 hours after fixing the horrible tapping noise I've had for so long.
Stored Codes
P1884 (Unknown)
P1451 (Unknown)
P1482 (Unknown)
Pending Codes
P1451 (Unknown)
First of all, check all your fuses and relays and make sure they're all good. If you find no problems there, then you are probably going to need a complete wiring diagram. There may be a common ground or power associated with most or all of these codes. I use mitchelldiy.com, it costs $17.99 for one month, but their diagrams are really good and they have power and ground distribution diagrams that I usually use for multiple problems like this.
Geordon Sparks Orbical Taylor (05-14-2020)
Looks like you have a pretty nasty voltage differential between your engine / alternator and the frame.
Here is what I would do:
1) make sure the braided grounding strap is there from the driver's side USA side head to the firewall.
2) Check all the grounds on the engine down below where the alternator grounds and all the wires run down into one place. This is deep
on the passenger's side - front of the engine - sort of near the pulleys.
All the wires ground well.
3) If you are missing a ground - be careful the handbrake wire does not burn off. Truck could try to ground thru that wire.
4) Make sure your alternator and battery are in really good order.
5) Check any grounds to the frame - by loosening the bolt - then retighten.
The "Shorted" seems to mean the voltage is railed to one end - high or the other - low.
Could happen by a voltage differental between engine and frame.
You could try a volt meter.
Put one lead on the body. The other to the alternator casing or anywhere on the engine.
If there is no voltage differential, then you
really do have all those codes.
Try
http://enginecodemaster.com
to understand some of them.
Best,
J
Try
Best,
J
Check fuses for the supply for the sensor heaters.
You may have one sensor shorted and that blows the fuse.
And makes them all go down.
Wow but if you were in water, then the sensor's did a hot to cold really fast
and may have gotten damaged. Or SILT has wrecked them. Hard to say.
Seems you are missing a bias voltage on one end of all these circuits.
That may come from the ECU.
Did the ECU get wet?
Stored Codes
P1884 (Unknown)
P1451 (Unknown)
P1482 (Unknown)
Pending Codes
P1451 (Unknown)
Stored Codes
P1884 (Unknown)
P1451 (Unknown)
P1482 (Unknown)
Pending Codes
P1451 (Unknown)
