Cat. Conv.
Old Jun 27, 2023 | 04:41 PM
mark j's Avatar
5th Gear
Default Cat. Conv.
My mechanic replaced the cat. conv. on my '03 Disco and it creates a loud exhaust sound 35-45 mph. How can it be corrected? Thanks, Mark. I'm new at this forum so I'm kinda slow.
Old Jun 27, 2023 | 04:52 PM
ahab's Avatar
He (they?) probably replaced it with an aftermarket system that's not nearly as soundproof as your original and you're hearing a byproduct of that. Unless you want to for over a couple thou for an LR version then you might as well get used to it. Beyond that, inspect for leaks.
Old Jun 28, 2023 | 05:53 PM
Discorama's Avatar
Test for leaks first, I second that. Attach a compressor to the exhaust (find a plastic bottle that fits into the pipe and attach a Schrader valve or quick connect to it) and spray soapy water on all exhaust connections (when the system is cold of course).
mark j
Mar 21, 2023 10:28 PM
andino
Oct 18, 2022 05:56 PM
AFDisco ll
Oct 20, 2015 08:32 AM
sawadeh
Oct 12, 2011 12:12 PM
JKK
Mar 4, 2006 01:29 AM
