Catalytic Converter..............
Old Feb 14, 2017 | 05:14 PM
Luckyjayb's Avatar
Originally Posted by gulfdisco
Those are sick and if i put them on my truck it would double its value lol
i love em. When I did the top end rebuild, I had everything powdercoated and all the heat shields and the exhaust manifolds ceramic coated
Old Feb 16, 2017 | 07:22 AM
cammyr01's Avatar
Originally Posted by LR03NJ
So youre taking the old cats from another disco, right? It its working, easier to swap the entire Y. If just the cats, it will cost you more to cu, install and weld. I am about to replace mine but I am considering getting the Y. Why, to purchase the cats and have it welded will cost just about the same if you purchase the entire new Y and bolt it yourself.
Yes, removed the y pipe and discovered it needs a weld, must have been damaged in the accident that totaled it. Which is why I thought maybe just remove the one cat that is causing the issue and swap it out.
or thinking maybe I can just get it welded but I'm a little concerned about if the well does not just write the whole assembly may not fit back on properly.
jwmstang
Aug 4, 2022 02:30 PM
JKK
Mar 4, 2006 01:29 AM
arocena409
Feb 13, 2006 01:08 AM
SUMOSINO
Feb 9, 2006 10:04 AM
mgm777
Jul 27, 2005 05:01 AM
