CD player display says "no disc" but I have discs
Old Aug 27, 2012 | 08:42 PM
kpl1228's Avatar
Originally Posted by lr2001silver
Take cartridge out then pull cd player out from under seat there are four little screws that hold the top cover on, remove them and re-grease the little gears inside cd player. Over time the factory grease dries up and the gears get stiff once you get gears greased up...
what kind of "grease" should I use?
Old Aug 27, 2012 | 09:25 PM
lr2001silver's Avatar
Banned
I used di-electric grease just in small amounts remember they are small gears and do not need a whole lot. I don't think you have to use that just what i had in arms reach. You could probably use anything really. Good luck, don't loose your screws.
Old Aug 28, 2012 | 01:46 PM
matt3502's Avatar
how does the top cover to the player come off? I took the screws out but the cover did not want to come off.
Old Aug 28, 2012 | 02:30 PM
Banned
The top cover tucks inside the housing get a small flat head and gently pry open then you will see where it slips inside the sides. You can start in one place and work your way around until top cover pops up. Remember to plug back in once top is removed and start to run threw a cycle so you can get a idea for what gears turn, then apply you grease to the gears and run threw a few cycles again to work grease into gears to confirm everything is turning smoothly. You may find animal hair or little chunks of dirt in-between the teeth of the gears not allowing them to turn with ease clear any debris out and then apply grease!
Old Mar 1, 2015 | 06:05 PM
usernme6789's Avatar
Default Fixed Mine
Upon reading this forum I went outside and tried a couple of things. When I bought the 2003 Range Rover HSE the cd tray would not remove. I did the tap it with the screwdriver fix and it came out. I then continued to listen to burned cds for approx a week successfully and the cartridge would eject fine. After that week I tried to play a disc it would eventually say no discs. In conclusion the same fix for removing the tray (hitting the tray with the back of a screwdriver while holding the eject button) is the same fix for this problem minus holding the eject button. Now in order for it to actually read the cds I must eject the tray, put cds into the tray, re-insert the tray into the cd changer and then tap on the tray with the back of the screwdriver until it finished reading all of the discs. It seems as though the grease inside has worn off of the gears and tapping it helps the mechanisms when they get stuck.
Old Mar 2, 2015 | 01:25 PM
Motorhead1's Avatar
Mine will say "CD ERROR". I carry a can of air in the glove box just for spraying down inside the cd player when the cartridge is removed, then it works again (ususally). Just need to get a better stereo and plug the phone in....on the list.
Old Mar 2, 2015 | 03:28 PM
Big Jim Swade's Avatar
Mine was doing that a couple of years ago. Instead of trying to fix it, I sent the head unit off to GB 4x4 Radios and had a mp3 player jack installed and it's worked great since then. I haven't missed the cd player at all.
GB 4x4 RADIOS
Old Mar 2, 2015 | 05:32 PM
sdhow's Avatar
Talking CD player display says "no disc" but I have discs
Why does it say "PAPER JAM"...when there is NO PAPER JAM???
Old Apr 12, 2016 | 06:50 PM
DiscoBuckeye's Avatar
Did this fix work?
I have the same problem.
Old Apr 13, 2016 | 05:25 AM
matt3502's Avatar
After fooling around with mine for a while and getting marginal results, I finally gave up and got a used one from Paul Grant. Very reasonable price.
paulgrant@mac.com
TenMan1
Jun 10, 2017 12:32 AM
RobsRover
Nov 9, 2010 05:35 AM
iownme
Nov 17, 2009 05:58 PM
ontheroadagain
Apr 17, 2006 11:57 AM
