CDL cable & shifter
Old Apr 23, 2015 | 08:34 AM
  #21
acamato's Avatar
Originally Posted by jsugden
On a related note, on a D2 which needs the front cone swapped, is the wiring there for the diff lock sensor switch or does something need to be rigged up?
EDIT: I found a great article here which addresses the question of wiring the diff lock sensor: 2003CDLInstall - LAND ROVER CLUB V.I.
In many cases the wiring is ready and waiting but if it isn't, this article tell you how to wire it yourself.
Here a overview of installin a cable style shifter: www.discovery2.co.uk/Factory Diff Lock
It also discusses the electrical portion at the end.
Old Apr 23, 2015 | 08:45 AM
  #22
jsugden's Avatar
Thank you but the electrical section in that article only covers how to address the SLAB programming disabling TC, not connecting the Diff lock sensor.
Old Apr 23, 2015 | 01:39 PM
  #23
acamato's Avatar
What year is your DII? You may not need to swap out the core or wire up the switch. Mine is a 00 and the switch was already wired. I just needed to install the shifter.
Old Apr 23, 2015 | 01:46 PM
  #24
jsugden's Avatar
Unfortunately it's an '02 so there isn't a nipple for the diff lock. I have the cone, I just need to swap it in.
Old Apr 23, 2015 | 02:01 PM
  #25
drowssap's Avatar
is that a Kalahari just dressed to look like one?
Old Apr 23, 2015 | 02:36 PM
  #26
jsugden's Avatar
It is a Kalahari although the picture is a year old and I've cleaned it up a bit since then.
Old Apr 24, 2015 | 12:20 AM
  #27
Rover_Hokie's Avatar
FYI, front cone = front output assembly to the part guys. I got mine from Paul Grant for $100, and it was shipped in a Home Depot bright orange bucket delivered by UPS.
Old Apr 24, 2015 | 08:13 AM
  #28
jsugden's Avatar
Did you do the work yourself? Any tips? It seems pretty straight forward. The only concern I have is dealing with the removal of the cats and the rust on the connectors.
Old Apr 24, 2015 | 09:14 AM
  #29
DustyLBottoms's Avatar
Douse the bolts with PB blaster for a week before hand, then hit 'em quick with an air gun. Slow/steady pressure from a breaker bar will just snap the heads off.
I would have new gaskets and bolts ready just in case, it wouldn't hurt to be prepared.
turbodave
Mar 29, 2019 07:22 AM
Francopacks
Apr 30, 2013 12:33 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
nickm347
Feb 16, 2010 12:53 PM
tibyABv6
Dec 14, 2009 01:06 PM
