cdl/D2/blown ftprop shaft
Old Apr 22, 2012 | 11:27 AM
onewingman's Avatar
Default cdl/D2/blown ftprop shaft
So, I've been cruising around the archives, etc and I'm still not totally sure. My question: '00/D2, does or does not have a CDL? My life would be a lot better, if I could give a 1/4 turn to the 13mm bolt on my tc, pull the ft shaft and be happily on my way to my driveline shop...
Oh, & is that the right procedure...1/4 turn on the 13?
Thanks
Old Apr 22, 2012 | 11:37 AM
jafir's Avatar
It should. But if you aren't the original owner or aren't sure of the service history, the only way to know for sure would be to feel for it. The transfer case could have been replaced at some point.
Old Apr 22, 2012 | 11:40 AM
wilson96rr's Avatar
Probably has the cdl. Best way to tell is to crawl under it and feel on top of the transfer case for the little turning part. It is right about where the front driveshaft comes out of the transfer case. I don't think the part that you turn is 13 mm. I think it is more like 8 but not possitive on that. Either way, pliers will work.
Old Apr 22, 2012 | 11:54 AM
onewingman's Avatar
Thanks! I'm on my way down under shortly. In one of the posts/pix I saw there was a little "lever" over the ft yoke on the tc, is that the critter? I'll go & see/feel what I find...
Thanks again
PS after the head R&R & fathoming the cooling system and doing a couple mods, it's running it great. I'm still abit shell shocked...I really don't need a blown tc at the start of the season...
Old Apr 22, 2012 | 02:09 PM
onewingman's Avatar
GOT IT!!! an 11mm wrench, 1/4 turn, click...it was just that easy...Unbelievable after some of the other engineering conundrums found between the bumpers of these rigs...Thanks for your help and I'm off to the driveline shop 2morow...
Tho, I'm not really sure the joints were the problem...just because those pesky li'l roller things fell all over the ground when I pulled the shaft...lol
Thanks again!
Old Apr 22, 2012 | 05:42 PM
richarddeel's Avatar
7th Gear
Did this let you drive the Rover with the front driveshaft out? I just pulled mine out and it was destroyed in the double cardon joint. Did you turn it clockwise or couter?
Thanks,
Rick
Old Apr 26, 2012 | 10:01 PM
onewingman's Avatar
Richard, sorry bout not gettin back sooner...but, YES! It drives fine. I'm thinkin I want to find a small solenoid to operate the thing. On mine there was no little lever...just an 11mm lug w/ about a 3/4" threaded stud coming out of it...I can't see it from underneath...it's most likely a post machined out of a square rod and turned down and threaded to make the lug...it felt square...no visual confirmation on that, just what it felt like. Mine's a '00, D2. Good luck!
Old Apr 27, 2012 | 05:42 AM
drowssap's Avatar
more 00 have a cdl, but not all. all later year build quite possibly may not have it.
Old Apr 27, 2012 | 07:31 AM
First, all 00's have CDL cases and about 85% of the 01's also have it.
As for the solenoid, I bought an solenoid kit made down under, about 10 years ago and it works great. Unfortunately they are no longer made.
Old Apr 27, 2012 | 09:36 AM
onewingman's Avatar
Default the solenoid
Too bad they stopped making it...add it to my list...I still haven't gotten 'round to fixing my OBD port and finalizing the wiring on the coolant temp gauge...and add an oil pressure guage...An Alfa Romero factory tech told me 40 yrs ago"I replace the oil pressure sending unit every time I rebuild an engine!..." And he was one tight guy, additionally, the idea on an idiot light for o/p wasn't even on the table...
all food for thought for an engine w/ a $4K rebuild...
Thanks for the good 411.
PS following the other CDL thread ongoing, I was LUCKY, it just worked perfect!
turbodave
Mar 29, 2019 07:22 AM
BrandonS
Jan 6, 2015 09:30 AM
pgk
Apr 3, 2012 12:13 PM
psykokid
Oct 30, 2011 10:46 PM
lipadj46
Feb 11, 2010 07:45 AM
