CDL install gone wrong.
I really need some help.
I've installed a CDL nosecone (used), Ashcroft CDL shifter, and CDL Harness YMQ105170.
I've verified Ive install the harness correctly and the nosecone is properly installed as well.
There are 3 issues I'm fighting.
1. My transfer case indicates neutral with the warning light and beeps when in Low Range.
2. My CDL light only comes on when the gearstick is in reverse?
3. CDL Harness YMQ105170 doesn't connect to anything on my harness as far as I can see. I have the CDL hooked up to the trans harness. so where does this harness go?
I'm thinking I need to adjust my transfer case to correct issue 1. As for issue 2&3 I'm at wits end.
Can you help me out?
UPDATE: Item 2 has been resolved. Fuse 25 was blown. Replaced and now the CDL light stays off.
Item 1....I'm going to adjust the transfer case to see if that will get the transfer case light off.
Item 3. Is the harness only if you use a 04 nose cone with the dual sensors?
