CDL Install Question
So I've finally got my Ashcroft CDL bolted in (what a monumental PITA that was), but I can get the center console middle plate to rivet back to the main body of the console. The biggest rivets I've got are 3/16", does anyone know how large are needed to get the 2 pieces back together? Or are there any other tricks I should be trying? Thanks
I might be wrong about my measurements, so measure the holes before you hit the hardware store.
But it did work pretty well. Also - I initially left out the inner CDL shifter boot, and I left the foam out. I was amazed how much louder the road noise was. I managed to stuff the inner boot down thru the console, which helped a lot. Next time I have the console out, I'm gonna cut the foam to accommodate the CDL shifter and put it in there too, though it may require removing the inner boot. I can't remember, but I think the inner boot was a D1 thing. I think the D2 just had the foam. I plan to cut the foam in an inverted pyramid shape to allow the shifter to move while blocking as much noise as possible.
While on this topic, I have had mine installed for a while, but not used much. I found the notes on the wire to cut to allow the traction control to stay on with the CDL for the earlier model D2s when you stop and re-start the D2 without having to shift out of CDL before turning the vehicle off and then shifting into CDL again once the vehicle is started. The notes reference 3 ECU units under the glove box on the passenger side. These notes appear to be from the UK, so I wanted to confirm that the 3 ECUs referenced, and therefore the general location of the wire in question to cut or add a switched to is located on the passenger side under the glove box in the NAS models as well. Can someone confirm this?
turbodave
03-29-2019 07:22 AM
