CDL Install Question
Old Jan 21, 2014 | 06:05 PM
etsZac's Avatar
Default CDL Install Question
So I've finally got my Ashcroft CDL bolted in (what a monumental PITA that was), but I can get the center console middle plate to rivet back to the main body of the console. The biggest rivets I've got are 3/16", does anyone know how large are needed to get the 2 pieces back together? Or are there any other tricks I should be trying? Thanks
Old Jan 21, 2014 | 06:46 PM
dr. mordo's Avatar
I bought bolts with pointed tips that worked perfectly. As I recall, the threaded part was ~1/4", the head was 1/2", and they were 1/2" long. I used a cordless drill with a socket bit to drive them in.
It was easily the easiest part of the job.
Old Jan 21, 2014 | 06:55 PM
etsZac's Avatar
Awesome, that's exactly the info I needed. Thanks a ton.
Old Jan 21, 2014 | 08:28 PM
dr. mordo's Avatar
I might be wrong about my measurements, so measure the holes before you hit the hardware store.
But it did work pretty well. Also - I initially left out the inner CDL shifter boot, and I left the foam out. I was amazed how much louder the road noise was. I managed to stuff the inner boot down thru the console, which helped a lot. Next time I have the console out, I'm gonna cut the foam to accommodate the CDL shifter and put it in there too, though it may require removing the inner boot. I can't remember, but I think the inner boot was a D1 thing. I think the D2 just had the foam. I plan to cut the foam in an inverted pyramid shape to allow the shifter to move while blocking as much noise as possible.
Old Jan 22, 2014 | 06:12 AM
drowssap's Avatar
you can also get some thing call rivet nuts, you install the rivet nut into the floor pan with a rivet gun then use machine screw into the rivet nuts. that way there is nothing sharp sticking threw the floor to chew you hand up.
Old Jan 23, 2014 | 08:20 PM
Rover_Hokie's Avatar
While on this topic, I have had mine installed for a while, but not used much. I found the notes on the wire to cut to allow the traction control to stay on with the CDL for the earlier model D2s when you stop and re-start the D2 without having to shift out of CDL before turning the vehicle off and then shifting into CDL again once the vehicle is started. The notes reference 3 ECU units under the glove box on the passenger side. These notes appear to be from the UK, so I wanted to confirm that the 3 ECUs referenced, and therefore the general location of the wire in question to cut or add a switched to is located on the passenger side under the glove box in the NAS models as well. Can someone confirm this?
turbodave
Mar 29, 2019 07:22 AM
sideshow
Dec 30, 2012 07:36 PM
bballjames
Oct 26, 2012 05:16 PM
FlyingZebra34
Feb 28, 2012 07:20 PM
dcarr1971
Oct 26, 2010 01:26 PM
