CDL kit Discussion [Center Locking Differential]
Old May 26, 2013 | 07:40 PM
  #31
dr. mordo's Avatar
yes, it will.
Old May 27, 2013 | 01:22 AM
  #32
Rover_Hokie's Avatar
X2 on verifying CDL presents and not assuming anything based on the model year and build date. I had an early '01 that came off the line in 2000. I sourced a D1 shifter without confirming, opened the center console, and no nipple. Had to add the front output assembly. After some research on the VIN by Will Tillery, it had come with CDL, but was swapped out during warranty period by LR for the PO with a non-CDL transfer case.
Old May 27, 2013 | 07:43 AM
  #33
ZGPhoto's Avatar
Originally Posted by SWAINROVER
would it hurt to run with cdl lock all the time ?
Do not do that!
Old May 27, 2013 | 11:16 PM
  #34
captain203's Avatar
finished shifter install and now working on re assembly. Had to open a fairly large hole in the tunnel plate to clear the D1 shifter. Is this the norm? I am planning on a rubber seal to cover the opening.
Old May 27, 2013 | 11:44 PM
  #35
Yes that is the norm, approximately 3-4" inches square opening in mine IIRC, but you will want a boot to keep the heat out.
Old May 28, 2013 | 10:22 AM
  #36
bballjames's Avatar
Also make sure to use RTV. The first time I installed my CDL shifter, I didn't really do a good job of sealing all the way around. It was noisy. And hot air came up. Later, I had to replace my CDL detection switch. So the second time I reinstalled the shifter plate I made sure to put a good coat of RTV all the way around. Very quiet and no air. In fact it is even quieter than before I did my CDL install.
Old May 28, 2013 | 10:26 AM
  #37
Paul Grant's Avatar
Cool
Try it and see. I have tons of parts to sell. It will wind up the drivetrain eventually damaging, at the very least, a differential. Frankly, I thing the fact that most people didn't use or even understand the point of a locking center differential is one of the major reasons why Land Rover abandoned it.
Old May 28, 2013 | 10:35 AM
  #38
drowssap's Avatar
good point
Old May 28, 2013 | 10:59 AM
  #39
captain203's Avatar
Ok update and an issue. I just did a road test well field test behind the shop. The CDL is working and I get the dash light. I can hear it engague and disengauge. The issue is I can not get low range. History. When I got tbe truck the range shifter was moving freely. Turned out the cable was dis connected at the range selecter on the case. Now everything is connec
ted and I can not move the selector into low range while rolling slowly and in "N". I assume there is some sort of lock out to prevent range change while in gear or park. Could this be the issue?
Old May 28, 2013 | 11:53 AM
  #40
wreckdiver1321's Avatar
In park, when you're trying to get it to shift into low, tap the throttle to raise the RPM a bit, apply pressure on the xcase lever, and let off the throttle. It should slot right in. Mine did that.
But then mine worked using the neutral method too. Strange.
