CDL Lock Out Solenoid wiring
Old Jan 22, 2017 | 11:00 PM
DailyDrivenTJ's Avatar
Default CDL Lock Out Solenoid wiring
Hi guys,
I got the CDL from 04. It has solenoid that locks the lever position. I guess it wires like the old one or does it have to wired specifically?
Thank you.
Old Jan 23, 2017 | 09:07 AM
Best4x4's Avatar
Originally Posted by DailyDrivenTJ
Hi guys,
Thank you.
I'm gonna take it that you have a 99-03 D2 and you added the 04 CDL Linkage. If so you will have the 4hi/N/4lo interlock solenoid on the transfer case. Then when you add the 04 Linkage it has the 4hi/N/4lo interlock solenoid mounted on the actual shifter assembly.
You basically have two choices. Bypass the unit on the Transfer Case & just plug in the 04 interlock solenoid into the old solenoids place and call it a day (better in the long run as the 04 setup us easier to get to). Or just bypass the 04 interlock solenoid and keep your original setup.
The CDL itself does not have a interlock. The interlock on our D2's keep you from going into N or 4lo while in gear. CDL is just cable activated via the lever going left/right and it can be done in gear.
Old Jan 24, 2017 | 02:09 AM
I can see how the CDL lever works.
I am not sure if I am following your second paragraph.
If I am understanding this correctly, there is a lock out on older D2 where the solenoid is located at the transfer case?
How do you "bypass" the 04 solenoid? Is this done electronically to permanently turn on the solenoid or permanently cut the actuator?
Old Jan 24, 2017 | 08:47 AM
Best4x4's Avatar
Yes older D1/D2's the interlock is mounted directly onto the transfer case. With the 04 linkage they moved it away from the transfer case and mounted directly to the 04 linkage. To bypass it you can cut the solenoid rod off, or use a zip tie or wrap it with tape to prevent the solenoid actuator from blocking the 4hi/n/4lo selector.
Old Jan 25, 2017 | 01:56 PM
Disco Stu AZ's Avatar
When I acquired my 04 linkage kit I simply removed the solenoid and wiring entirely from the unit. You'll need to scrape the caulking/glue stuff away from the front of the solenoid then you'll simply remove a c clip and pull out the solenoid itself. Super easy to do.
Old Jan 25, 2017 | 02:02 PM
Big Jim Swade's Avatar
That's what I did when I installed a 04 CDL last year in my 2001. Just remove the
silicone calking, take out the snap ring and the solenoid will come out.
turbodave
Mar 29, 2019 07:22 AM
hh65flyer
May 1, 2018 09:22 PM
KingKoopa
Jan 24, 2017 01:31 PM
A5scott
Aug 4, 2012 04:51 PM
twaszak
Jun 27, 2011 01:32 PM
