CDL Ordered
#21
Its a son of a B. I just did it about 3 weeks ago, using a D1 shifter. Call me if you get stuck. My front output would not come forward with the output(diff gears) housing removed. Mine all went back together fine. I ended up having to remove the rear output, Emergency drum brake, rear propshaft and housing. Once I removed that The front slipped past those gears.
Call me if you need help
317-201-2847 Anytime after 12noon
Dave Kimsey
Dave Kimsey
#22
Thanks, I will. I need to get the old one out. We worked on it for 5 hours and with all the rust it is a pain. I broke the 4 rear cross member bolts on the drivers side, I plan to wield the thing back in, and did not have to remove the front cross member. I hope to get it back together Saturday and I still need to get the Amigos to go off.
#23
#24
Done the install and everything seems to be working, except a exhaust leak and another issue. I need some help with this one. When I put it in 4lo the little light on the dash that has gears with a line through them comes on and it beeps. The Disco still drives, but the beeping and the light is an issue.
#25
#26
Its just sensing that the xfer box is fully engage, like being half in gear that might pop out in a manual shift car as far as i understand that light. sometimes it can be tricky to change fully from lo/high... are you changing at rest or while at slow speed? mines far easier at slow speed but takes some getting used to.
turbodave
03-29-2019 07:22 AM
yayo
01-17-2007 07:50 PM
Disco Alan
07-14-2006 01:28 PM
