CDL part?
Old Mar 29, 2018 | 07:57 AM
oaty's Avatar
Default CDL part?
Does anyone have the part that mounts to the diff, shown in the above pic. I have a CDL unit minus the part that mounts to the diff. The elbow with two holes?
Thanks in advance.
Or is there another option to installing a CDL in my 2000 D2? We took the CDL linkage out of a 2004 D2. We could not grab the mount attached to the diff.
Old Mar 29, 2018 | 08:21 AM
Alex_M's Avatar
You mean the transfer case? There's no locker in either diff.
Wouldn't be too hard of a mount to fabricate if you had the tools.
Old Mar 29, 2018 | 09:51 AM
acg's Avatar
acg
This Polish seller on Ebay used to make his own kits which are similar to the factory design. You could check with him and see if he can supply you with the part:
https://www.ebay.ca/itm/111078180757?rmvSB=true
Or perhaps ask him if he can supply some dimensions so that you can get a local fab shop to make the bracket for you.
Good luck!
Old Mar 29, 2018 | 10:53 AM
oaty's Avatar
Default Yes and thanks
I’ll check seller out
Old Mar 29, 2018 | 11:10 AM
Jeff Blake's Avatar
The part number is IGU000030, however LRDirect no longer stocks it. Some other sellers do, but usually I find if LRdirect doesn't, then other sellers websites are out of date. I'd recommend to check with guys like Abran, Paul Grant, and Will tillery, but I imagine they sell this part along with the CDL shifter.
Old Mar 29, 2018 | 01:55 PM
oaty's Avatar
Thanks. I may can fabricate it. But would rather get a used one. If I can go back to the loaner vehicle the cdl came off of (hours away) I may can grab it.
Thanks so much.
Old Mar 29, 2018 | 03:52 PM
DavC's Avatar
semantics aside, transfer case = centre differential
That's why CDL is Centre differential locking
Old Mar 29, 2018 | 05:11 PM
Jeff Blake's Avatar
if we’re being technical, the center diff is a component of the transfer case, one of 3 shafts.
Old Mar 30, 2018 | 10:03 AM
Alex_M's Avatar
Yep. I wasn't trying to be a dick. It was confusing terminology because 99+% of the time when someone says "diff locker" they mean an axle diff. I genuinely didn't know if OP knew the difference because there was a text that I didn't either.
turbodave
Mar 29, 2019 07:22 AM
BrandonS
Jan 6, 2015 09:30 AM
grandkodiak
Mar 14, 2013 05:15 PM
coors
Feb 7, 2012 09:15 PM
lipadj46
Feb 11, 2010 07:45 AM
