CDL Question
Old Aug 1, 2019 | 10:08 AM
jdbayer's Avatar
Default CDL Question
The previous owner had a transfer case from an 04 installed that has a CDL but didn't install the linkage. So I have the feature but no way to use it. Do I just need to buy the shifter from an 04 for this to work or is there more I need? Will this item from Ebay work?
https://www.ebay.com/itm/Land-Rover-...2b1f706da9e4e1
I appreciate your help.
Old Aug 1, 2019 | 10:52 AM
Best4x4's Avatar
What year is your D2?
You could grab an 03-04 SLABS Unit to make it 100% identical fo an 04 (fully supports CDL & it will have the latest firmware which helps with ABS/HDC/TC). Then slap in the 04 CDL linkage and call it a day.
Now if you have an earlier 99-02 D2 the interlock solenoid is actually on the TC vs 03-04 where it is mounted onto the actual 4Hi/N/4Lo linkage. You can stick with your original setup on the TC, but you will have to remove the interlock solenoid from the 04 setup. It’s not hard to remove. I personally remove the 99-02 TC interlock and go with the 03-04 unit as it’s MUCH easier to gain access to if it fails. TC mounted unit is a complete PITA to get to.
FYI in the future if you want more precise advice/help, filling out your signature with your vehicle info/setup makes it much easier for everyone to help.
Old Aug 1, 2019 | 01:42 PM
mln01's Avatar
All that Best4x4 wrote is correct, but to answer your direct question the shifter in the eBay listing you included is from a DI. It will work with your truck with some minor modifications. Installation is detailed in several threads in this and other Rover forums.
A t-case shifter from an '04 is a better choice, but they are more expensive on eBay and less commonly found. The ideal scenario is that you find a '04 shifter at a local boneyard, where they sell for much, much less. I bought the one in my truck that way for $75 several years ago, and in the last year I bought two more for ~$20 each.
Old Aug 1, 2019 | 02:09 PM
Best4x4's Avatar
Yeah the link wasn’t working for me sorry (wifi out on the job site). I prefer the 04 setup to the 94-99 D1 setup & as mentioned above it’s a more straightforward swap.
Last one off an 04 at LKQ was 30.00 complete with the plate, ****, linkage, and shifter boot. I also grabbed an 04 SLABS Unit for 15.00 (they put it down as a Cruise Control ECU).
Old Aug 1, 2019 | 06:36 PM
jdbayer's Avatar
I have an 03. The TC the PO put in was from an 04. He said I could get the linkage from an 04 and it would work. Thanks for the info y’all.
Old Aug 2, 2019 | 06:13 AM
redwhitekat's Avatar
I just did this it’s actuslly pretty easy
my transfer box is out of a 99 and I got a 04 linkage fits right in
Okie Rover
Jun 14, 2013 02:07 PM
Disco_Fever
May 15, 2013 10:53 AM
XxRoverAllOverxX
Mar 7, 2011 10:09 AM
mdf27
Feb 22, 2011 05:09 PM
Disco Den
Mar 18, 2010 08:10 PM
