CDL stuck in 4H
Old Aug 23, 2018 | 02:16 PM
DavC's Avatar
It will not drive in N... again 4H is how you drive it on the road. You mean 4L? Or you mean you got the diff lock on? Are you aware of how these systems work?
Like I said, crawl under the car and soak the linkage in WD40.
Hope you figure out that the CDL linkage and the 4H 4L linkage are literally separate. Please don't break your car.
Old Aug 23, 2018 | 02:31 PM
Richard Gallant's Avatar
Originally Posted by JeffStu
My CDL is stuck in 4H I can't get it to shift back to N. 2001 disco 2, the previous owner installed the CDL shifter/linkage. Still asking if anyone has tips or tricks for getting my CDL from 4H to N. Thanks.
Ok I know this will sound condescending but there appears to be some confusion.
  • Discovery's are full time 4 wheel drive there is no 2 wheel drive option
  • The CDL lever does 2 things Goes form Hi to Low range - HI range being the normal driving position
  • Depending on the year of your Discovery it can also lock the center differential you have an 01 so it may or may not
  • For normal driving the CDL level is all the way to the rear and all the way to the right
I have attached the section from the owners manual the details how use the transfer case, it tends to be referred to as the CDL lever on a lot of sites.
File Type: pdf
Old Aug 23, 2018 | 03:10 PM
Best4x4's Avatar
4WD Selector **** Forward/Back Operation is as follows:
4Hi
N
4Lo
94-04 CDL Function if so equipped Operation side to side is as follows:
<- Left Engaged | Right Disengaged ->
”If” up/movement isn’t happening allowing you to shift the TC between 4Hi, N, and 4Lo isn’t operating then your interlock solenoid is most likely INOP. On 03-04 models it’s located on the 4WD selector assembly. On 94-02 it’s mounted directly to the TC.
Only other thing would be a binding shift cable.
Old Aug 23, 2018 | 09:55 PM
JeffStu's Avatar
That was it. Thanks for the help.
seems counter intuitive compared to the diagram, but it works.
Old Aug 24, 2018 | 05:33 PM
JeffStu's Avatar
One big takeaway from this is that I never was sure how exactly I got the CDL engaged. It was easy disengaging once I had the good info.
With the type of CDL I have, sliding left to engage and right to disengage, is there even a high or low gear range selectable? The labels are ****
Old Aug 24, 2018 | 09:27 PM
DavC's Avatar
How do you have a drivers license? Nearly every comment on this thread describes it for you. High is forward low is to the rear. You have a standard setup for the transfer box with locking centre diff.
This transfer case design has been around from 1983 to 2015...
samroy92
Jul 18, 2016 09:42 AM
scottmb23
Dec 24, 2013 06:11 PM
tornado_735
Mar 19, 2010 08:44 AM
Camdisco24
Dec 13, 2008 09:34 AM
tomfraser
Dec 7, 2008 03:54 PM
