CDL will not shift to the left in either high or low range - please help
Old Jul 10, 2014 | 06:44 AM
drowssap's Avatar
To the OP, you don't have to remove the lever to disconnect the cable.
Old Jul 10, 2014 | 11:07 AM
TRIARII's Avatar
Thank you for the suggestions. I will give it a shot this weekend. I would not mind popping out rivets and using a rivet gun and drill but i dont have neither of those tools yet. Ill try disconnecting the cabin from under the truck and try moving the lock with a wrench. If i run into any problems disconnecting or reconnecting that cable, will that prohibit the truck from normal operation? Seems like more often than not a simple tast ends up being a problem. Often times due to rusted or stripped bolts and nuts that break....
Thanks again
Old Jul 10, 2014 | 01:28 PM
WNYErikDiscoII's Avatar
Former Sponsor
Thanks again
A broken cable will not prohibit the truck from movement, but a transfer case stuck in neutral will. You can run the truck in locked or unlocked mode no problems, you will just have a tougher time turning in locked.
Old Jul 12, 2014 | 03:36 PM
TRIARII's Avatar
Smile CDL fixed and working again!
Originally Posted by WNYErikDiscoII
We have had luck by first actuating it manually. Climb under the truck with a 10mm wrench, fit it on the nipple and try and turn it 2 clicks towards the passenger side, then 2 clicks back to the drivers side. Very often the linkage is stuck and you just need to un-stuck it manually before you can use your shifter to actuate it normally.
Here is a video we made to show what you're looking for:
How to lock a Land Rover Lt230 - YouTube
Thank you! Tried this and it worked! A wrench did not work for me because i could not for the life of me get a grip on the nipple so I tried a ratchet with a 1/2 socket to actuate the nipple manually. Moved it several times back and forth then I applied generous WD-40 and now I can shift into diff lock in both high and low range. Shifter moves easier now to. Turns out I was lubricated the wrong side of the truck. There is some linkage on the driver side up between the frame and the transmission that I thought was linked to the cdl. Been lubricating it for quite awhile in vein.... my bad.
Thanks so much man and thanks everyone on this forum.
Old Jul 12, 2014 | 10:01 PM
ZGPhoto's Avatar
Don't use wd-40 to lubricate!!!!!!!!!!!!
DadOfRoverOwner
Jan 16, 2021 07:32 PM
Motorhead1
Dec 26, 2019 10:55 AM
floundering
Aug 25, 2013 09:48 AM
hubie
Apr 5, 2012 07:12 AM
srfnsno99
Aug 28, 2011 10:46 AM
