CEL: 02 sensors - why?
Old Jun 6, 2020 | 10:15 AM
ReconDoc83's Avatar
Default CEL: 02 sensors - why?
While Disco was on the lift during head gasket job I replaced all four 02 sensors....I am still getting CEL codes for the 02 sensors after clearing the codes...
why?
Old Jun 6, 2020 | 11:03 AM
redwhitekat's Avatar
Number of reasons
wiring could be broken or bad connections. Look closely at wires going into O2 plug.
Vaccum leaks ( smoke test )
exhaust leaks smoke test
bad purge valve. Causes misfires and bad combustion all sorts of headaches. Hyundai part cheap
Old Jun 6, 2020 | 12:08 PM
ReconDoc83's Avatar
Originally Posted by redwhitekat
Number of reasons
you have a link to the purge valve? Describe this “smoke test”? I’m almost positive there are no exhaust leaks...but vacuum leak....that might be another story.
Old Jun 6, 2020 | 02:25 PM
cvhyatt's Avatar
Check out this smoke test I rigged up.
https://landroverforums.com/forum/di...15/#post709433
here is a link to the Hyundai part
Genuine Hyundai 28910-22040 Purge Control Valve
Amazon Amazon
Old Jun 10, 2020 | 11:28 PM
Wheelspin's Avatar
I’ve had on going o2 issues on bank 2, there are mini cats installed, I guess to get around cat problems but still faults
they noticed that the o2 lead was close to ht lead, that fixed it for 3 days, now they have swapped over the front sensor lead for the rear, hopefully that will fix it
Old Jun 11, 2020 | 06:48 PM
Extinct's Avatar
Get an ELM327 off Amazon for $5, free Torque app on an android ($30 android off ebay if you have iphone). CHart the oxygen sensor voltage, post videos here.
aftermath431
Nov 2, 2014 07:59 PM
cobbcj7
Oct 15, 2014 11:11 PM
Rovermancz8
Mar 5, 2013 07:53 PM
urq
Feb 29, 2012 09:00 PM
