cel 2004 discovery
Old Jan 27, 2010 | 07:42 PM
wesley64's Avatar
okay,home from work now.took my son 4 blocks down to corner store.just as i was parking, it stalled.no flashing m&s because i have charged battery and have good connections.waited about a minute and it started.drove home and it stalled as i pulled in my drive way.again no flashing m&s and no service engine soon light.
i was reading in my searches on this form that it might be a crank position sensor.it almost sounds like there is no fuel as i crank it over.
is there a check i can do to confirm this?or would a cps fault throw the ses light on?
brett
Old Jan 28, 2010 | 11:47 AM
Mrmerlin's Avatar
what is the charge of the battery engine off?
what is the charging system giving when the truck is running at 2000 rpm??.
Check all of the fuses for corrosion and the starter connections and the alternator connections. do this with the battery disconnected
Old Jan 28, 2010 | 12:06 PM
Camdisco24's Avatar
Does it start fine when its cold, and then die once it gets hot?
Will it not restart when its still hot?
If so, it very well could be your crank position sensor.
Its common for it to stall once it gets hot if you have a bad crank position sensor.
Codes will be the tell all though... get them if you can.
Old Jan 28, 2010 | 12:46 PM
okdiscoguy's Avatar
There is a little schrader valve on the fuel rail to test fuel pressure. Looks like a tire valve. Fuel should squirt out
When it dies, turn the key on (not start) and wait 5 seconds, turn it off and repeat 4 times. This will signal the pump to turn on and build pressure for starting. If it starts, I think you will need a new pump. You can get a gauge to verify fuel pressure before buying a new pump..
Old Jan 28, 2010 | 02:50 PM
wesley64's Avatar
voltage with vehicle off is 12.3,running 14.2.
stalls when hot,started this morning when cold.
there are no warning lights on dash or ses light, no more m&s lights,assuming electrical system is good.
thanks
brett
Old Jan 28, 2010 | 04:04 PM
Camdisco24's Avatar
thanks
brett
I'm gonna say crank position sensor. Sounds just like same the issue I had when mine went bad.
Old Jan 28, 2010 | 04:45 PM
wesley64's Avatar
ok,they are $120 here at the landrover dealership in vancouver, b.c.,canada.i will grab one on the weekend.unless there are cheaper ones somewhere else.
brett
petedisco
May 5, 2013 09:14 AM
Dan87GT
Nov 5, 2010 09:13 AM
Jwilk
Nov 4, 2006 01:04 PM
jmang
Oct 22, 2006 11:25 AM
Corsair33
Sep 1, 2006 12:13 PM
