Center Console Repair
Old Aug 22, 2023 | 09:35 AM
Windycity_rover's Avatar
This is in my future. Thanks for the idea. Just a thought but since you have the center console out you should epoxy/reinforce the lower mounts on the switch panel. Mine started with top and then the bottom gave way. This plastic with time just weakens and becomes brittle.
Old Aug 22, 2023 | 12:06 PM
88Joe88's Avatar
I was thinking about that but the uppers are in perfect shape for now and hopefully I'll be more gentle than the previous owner. The Disco is just a fun weekend vehicle that doesn't see too many miles, I had the console out to free up the transfer case and CDL linkages (frozen solid when I bought it).
Old Aug 22, 2023 | 07:58 PM
Extinct's Avatar
I have had a couple pretty bad, had to splice in aluminum supports. Loctite PL3X - sand and flame treat the plastic for adhesion. let cure 24hrs
Old Aug 23, 2023 | 09:03 AM
sqlbullet's Avatar
I built a new backing plate using sheet metal from a rusted out bronco tailgate. I still need to re-align the window switches with the correct windows, but I keep putting it off since the next time I take that apart I have some work to do on the top of the t-case too.
Your fix looks solid.
Old Aug 23, 2023 | 10:16 AM
Externet's Avatar
Lightbulb
Whenever a curing paste/epoxy like Bondo, JBweld is used for a repair like these, remember to embed pieces of scouring 'brillo' metal wool pads into the paste mix soon, well before cures.
Paul Grant
Oct 2, 2018 08:16 AM
Jacobp
May 7, 2018 08:39 PM
TRIARII
Aug 22, 2016 11:25 AM
DivebombInc
Sep 16, 2011 08:22 PM
jck09
Aug 1, 2011 08:55 PM
