Changed all wheel bearings and abs sensors but now have constant lights
Thanks Best4x4.
So dumb question, when I replaced the front pads there was what looked like pad sensors on them. But the wire was short. Didnt look cut but just short. There was one on both sides. So thinking that they were not in use I tossed them. Are there supposed to be front pad sensors? Could that be why I am having lights? Thanks
I’ve got a little older Autel 619, not rover specific / but it did the job done until I invested in other scan tools. Both ABS & oBd2
What brand wheel bearings did you install- and did they come with sensors? Or did you source sensors & bearings separately?
. When reinstalling/ if I happen to carelessly swab debris or say a rust flake while sending back thru the axle housing and into hub, I’ve put everything back together & that has caused that fault code. The sensor is a magnet
