Changed all wheel bearings and abs sensors but now have constant lights
Old Jul 12, 2021 | 07:42 AM
me 2's Avatar
Thanks Best4x4.
So dumb question, when I replaced the front pads there was what looked like pad sensors on them. But the wire was short. Didnt look cut but just short. There was one on both sides. So thinking that they were not in use I tossed them. Are there supposed to be front pad sensors? Could that be why I am having lights? Thanks
Old Jul 12, 2021 | 11:20 AM
SundayFunday's Avatar
I’ve got a little older Autel 619, not rover specific / but it did the job done until I invested in other scan tools. Both ABS & oBd2
What brand wheel bearings did you install- and did they come with sensors? Or did you source sensors & bearings separately?
. When reinstalling/ if I happen to carelessly swab debris or say a rust flake while sending back thru the axle housing and into hub, I’ve put everything back together & that has caused that fault code. The sensor is a magnet
Old Jul 12, 2021 | 11:25 AM
me 2's Avatar
They are Ebay bearings that did come with the sensors.
Old Jul 12, 2021 | 01:04 PM
Like mentioned above. Scanning will tell you which one(s) is causing the issue. Could be inadequate contact in plug. Could be incorrect gap with sensor to bearing.
Old Jul 13, 2021 | 12:15 PM
me 2's Avatar
Okay, scanned with the icarsoft tool:
Shuttle Valve Switch Electric Failure
Rear Right Sensor Output Too Low
Front Right Sensor Electric Failure
Rear Right Sensor Signal Erratic
Lol, just a few issues!
Old Jul 13, 2021 | 01:39 PM
mollusc's Avatar
Looks like someone needs to do Option B on the WABCO ABS unit, and then check on the electrical connections from the wheel sensors.
Old Jul 13, 2021 | 01:42 PM
me 2's Avatar
Whats option B? Crazy cause I was having the 3 amigos occasionally prior to installing the new bearings/sensors. But immediately after the install the 3 lights are constant along with the brake light.
Old Jul 14, 2021 | 07:41 AM
mollusc's Avatar
Option B is described all over this forum in relation to the 3 amigos. Just search for it.
OffroadFrance
Jul 9, 2021 09:15 AM
iplayblues4u@comcast.net
Jan 6, 2010 08:43 AM
Willie 00D2
Sep 12, 2008 06:35 PM
dsmtrain
Jul 12, 2008 07:15 AM
Switzer
May 31, 2008 09:58 AM
