Changed the TC fluid.
Old Jun 26, 2010 | 01:59 PM
Danny Lee 97 Disco's Avatar
The only problem with the breaker bar is that after you break it loose, it is still a bitch to turn, at least with the ratchet, I could leave it seated and work it a few clicks at a time. The light was important to help keep it squarely seated.
The PB Blaster really helps, especially with a few days soaking time.
Old Jul 12, 2010 | 09:38 PM
batiscan's Avatar
Finally got around to do it. This time the filler plug came off rather easily with a small 8" extension on the ratchet. The drain plug came off easily too. There's nothing like a long PB soaking.
There wasn't too much shavings on the plug magnet, but the oil seemed slightly opaque.
I put in Castrol synthetic gear oil. The result was amazing. Much smoother and much easier transfer case shifting.
Old Jul 12, 2010 | 09:40 PM
batiscan's Avatar
Clarification: The extension used was a pipe on the ratchet handle. The 1/2 ratchet was inserted directly in the filler plug.
caymandrew
Apr 20, 2013 09:52 PM
Rover Curious
Oct 6, 2011 06:59 PM
LRScott
Mar 4, 2009 08:39 AM
humroot
Nov 11, 2007 08:58 PM
D2 2003
Mar 14, 2007 05:30 PM
