Changing Alternator...
Old Dec 20, 2006 | 09:12 PM
ITMagician's Avatar
4wd High
Default Changing Alternator...
Hello All and Disco Mike,
I was wondering if you could offer any advice on changing the alternator in a 2000 Discovery. I just purchased a brand new battery from Sears and after about two days of driving, the battery is dead. This happened to me in a Nissan over the summer, so I'm assuming it's the same issue with the alternator in this car - sorry - truck. I want to know if I should attempt to change the alternator myself ? I have the Workshop manual and the diagrams make it look pretty easy. Is there anything I should consider before starting this endeavor ?
Old Dec 20, 2006 | 11:23 PM
Default RE: Changing Alternator...
You know what they say about assuming???
Did they test your charging system before you bought the battery?
I would have someone load test the battery and alternator before yo do anything.
If the alternator is bad, it is an easy replacement, if it is the battery I would have sears reinburse you for their battery and get someone else's battery.
Get back to me if you have any questions.
Mike
Old Dec 23, 2006 | 07:46 PM
ITMagician's Avatar
4wd High
Thank you Disco Mike,
As it turns out, my negative terminal wasn't making proper contact with the battery terminal. I just cleaned it and it is now starting up and running fine. Didn't need to replace the alternator after all - not yet anyway.
crackofdawn
LR2
Aug 26, 2019 04:00 PM
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
arocena409
Sep 24, 2005 06:26 PM
winnegar
Sep 19, 2005 09:35 AM
