Changing coil
Old May 15, 2009 | 10:35 AM
tbuckt007's Avatar
Default Changing coil
Does anyone know if a coil pack can be changed without removing the IM?
Old May 15, 2009 | 09:24 PM
mwsharb's Avatar
I just did my wires today without removing the IM, and I don't see how you could change the coils without removing it. Just my $.02.
Old May 24, 2009 | 09:22 AM
tbuckt007's Avatar
Default Coil Change
Followed my RAVE instructions and removed IM and replaced the coil pack.All in all it was not that difficult.
Old May 24, 2009 | 08:21 PM
tailchaser0527's Avatar
You just have to remove the upper plenum.. It's extremely easy to remove, and well worth the headache it will save u..
Old May 25, 2009 | 01:53 AM
CandiMan's Avatar
I don't know which year is your Disco, but on a DI you do not have to remove the IM to change the coil pack. After disconnecting the coil pack harness and spark plug wires, there are 2 small bolts/nuts on each side of the coil pack bracket. Once everything is removed, the coil pack can wiggled out.
trialrun
Nov 11, 2014 08:41 AM
b_woodroaster
Nov 5, 2010 08:54 AM
dillhole
Aug 23, 2009 07:53 AM
arocena409
Sep 24, 2005 06:26 PM
winnegar
Sep 19, 2005 09:35 AM
