Changing the engine fluids other then the oil???
Old Dec 13, 2007 | 04:17 PM
Chrisinhouston's Avatar
Default Changing the engine fluids other then the oil???
My Disco is an 03 with 87,000 miles and was LR maintained as a lease vehicle up until 56,000 miles and seems to have had oil changed regularily after that. I noticed that the brake fluid and PS fluid is rather dark and dirty looking. I would like to flush these and replace with new fluids. Is this a normal DIY procedure on the Disco for someone with good mechanical knowledge? Anything unusual about the procedure or the materials needed?
I also want to drop the transmission fluid and replace the filter, etc. Would you folks suggest I could also do this as I have done it before on my old Suburban.
Thanks,
Chris
Old Dec 13, 2007 | 04:19 PM
willstevens's Avatar
Default RE: Changing the engine fluids other then the oil???
Search through this forum and you will find all the answers to those question is detailed form
Old Dec 13, 2007 | 04:33 PM
okdiscoguy's Avatar
search 60 K service. Mike has made up a great list. Also, you don't nee to change the tranny filter if it has been changed once.
Old Dec 13, 2007 | 05:27 PM
Here is a list to work from.
This is the parts list for a 60,000 mile service or a high mileage used truck, the way I do it.
1 Oil filter, K&N 3001
1 Air filter
6 Qts of engine oil
12 Qts of ATF
7 Qts of 80/90W gear oil
2 Qts of Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platium Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt if not yet replaced
2 Bottles of SeaFoam
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Flush the coolant system
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
Old Dec 13, 2007 | 05:59 PM
Thanks Mike, "you be the man" as they say. I had an Isuzu Trooper '86 T. Diesel and I became a Lucas fan there. Seems like an excellent lubricant and a couple of million truckers can't be wrong.
Chris
MurphyPeoples
Mar 11, 2015 06:01 PM
jeffmalone
Mar 13, 2010 09:23 PM
alpineclimber
Jul 29, 2009 01:26 PM
wildhorses
Oct 16, 2005 10:36 PM
