changing radiator in a 2002 Discovery
Make sure to replace the t/stat if over 75,000 miles on the truck, use only Dexcool and throw in a bottle of either Water Wetter or Purple Ice to improve your cooling system.
Do you know how to bleed the cooling system when adding coolant?
make sure to bleed the system of air correctly - it is harder than it sounds. Their is a sticky under the DISCOVERY heading on here, maybe the 2nd or 3rd post from the top. It has pretty good directions.
You'll need to remove the front turn signals. And the grill. And the horns. If you have a brush gaurd youll need to remove that as well. No, seriously. Its the most overcomplicated design for radiator removal you'll likely find. You'll need the rave. And some patience.
chup1
Sep 4, 2012 08:48 AM
dapo
Apr 25, 2009 01:22 PM
