Charcoal canister
Old Sep 11, 2008 | 03:22 PM
JerrodSteph's Avatar
Default Charcoal canister
I have a disco 1 with the 4.0. Do any of you have a charcoal canister on the passenger fenderwell? Are any ports left open? I just felt an open unused port on mine while the engine was idling and noticed vacuum pull there... I plugged it or is it supposed to be left unplugged for emissions or??? Thanks!
Old Sep 11, 2008 | 03:30 PM
Default RE: Charcoal canister
It is supposed to be plugged. Probablly with a vacum hose.
Old Sep 11, 2008 | 04:08 PM
Spike555 you have been most helpful! thanks!
Old Sep 11, 2008 | 05:07 PM
Landzu's Avatar
If you have a round charcoal canister you have a early EVAP system.
That is what I have and there 3 places for lines two are together one above the
other,, then on the motor side there is one open spot for a vacuum line to go.
Mine does not have a line on it and never has it can pull air in when the evap valve
is open to burn the fumes off the gas tank.
The early evap systems are much easier to work with.
Old Sep 11, 2008 | 09:38 PM
roverguy7's Avatar
landzu is dead on, it will have vacuum but only during purge valve activation, this is to get rid of the fumes in the canister, as long as the vent valve has not failed open, its normal... and you would have a check engine light and a p0455 code if it was failed
IronGold
Sep 12, 2014 12:15 PM
kingofvermont
Jan 19, 2012 08:59 PM
wheelgarage
Jul 5, 2011 10:47 AM
adigerol77
May 20, 2011 10:41 PM
MJSVG
May 13, 2006 11:03 AM
