Chasing the multiple misfires
Old May 23, 2025 | 12:55 PM
  #81
Tony Luna's Avatar
Originally Posted by JohnZo
By way of clarification, misfire codes are being produced, but there are no actual misfires in the cylinders. The jerky motion of a lopey idle at the flywheel is picked up by the crank position sensor as timing differences between teeth of the reluctor wheel. Then the ECU logic sets the misfire codes, based on timing differences. In this case, the engine is not actually misfiring, rather the logic that sets the codes is not suited to the new cam set up at low idle RPMs.
Glad you found that the A/C idle-up was enough to get you over the hump. Perhaps there's a way to wire in a switch or jumper to make the ECU think the A/C is on all the time.
John, thanks for the clarification. I never thought they were actual misfires based on all the work to try to solve it and on how well the truck ran - other than a little rough at idle.
The loaner performance ECU from TWS must take the lopey idle into account as I never had "misfire" codes for the 3 weeks I ran it. I have one on order.
And thank you all for all the help on this!
nickm347
Nov 1, 2021 02:44 AM
TimInNova
Jun 28, 2019 07:15 PM
big-boss
May 28, 2018 08:47 PM
Charlie_V
May 28, 2017 12:18 PM
Charlie_V
Jan 27, 2014 11:35 AM
