check engine light
Old Mar 6, 2008 | 07:26 PM
Default RE: check engine light
Are you saying you don't always run high octane??????????????????
That is a huge NO NO, so start there.
*** for plugs, buy either the Champion double platium or the Bosch Platium Plus 4's and use a set of 8 mm Magnacore wires.
Are you going to replace the wires yourself?
Old Mar 6, 2008 | 07:53 PM
underpsi's Avatar
i have found out she sometimes put mid grade in. i can put the plugs and wires on if my mechanic cant do it. is there anything special that i should know doing the plugs and wires? he wants to pull the plug and check it out and then check the wire on #3 cylinder, then go from there....
Old Mar 6, 2008 | 08:15 PM
okdiscoguy's Avatar
ORIGINAL: underpsi
I would go ahead and order a set of Magnacor 8MM wires and Bosch +4 plugs. If it needs #3 replaced, do all of them, and at your mileage, it is getting to be time. These plugs and wires are the best for your truck... The wires are a little difficult to change, and if you don't have seconday air emissions, you can do them one by one without removing the intake, but it is a lot easier with the intake off. Might get a gasket for that too...
Like I said before, premium only
Old Mar 6, 2008 | 08:17 PM
okdiscoguy's Avatar
ORIGINAL: Disco Mike
potty mouth......[:-]
Old Mar 6, 2008 | 10:30 PM
underpsi's Avatar
can i get those plug wires and plugs at an autozone or local auto parts store?
Old Mar 10, 2008 | 11:02 PM
underpsi's Avatar
ttt
Old Mar 11, 2008 | 11:24 AM
ORIGINAL: underpsi
Call Tony for the wire, at 650-365-4145, the plugs can be bought at any auto parts store. By the way there is a rebate on the Bosch plugs right now.
Old Mar 11, 2008 | 09:10 PM
underpsi's Avatar
thanks i wil do that
FlyingZebra34
Feb 22, 2014 05:39 PM
RoverZebra
Dec 8, 2012 04:27 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
