check engine light
Old Nov 30, 2008 | 07:04 PM
lrd2's Avatar
Default check engine light
ok so i plugged in the odb2 in at work today and came up with 7 different codes it said cylinder 2,4,6,8 miss fire o2 sensor 1 and 2 and o2 sensor main relay now i was under the impression that my car needed 89octane gas but i found out that it needs 93octane. is it possible that i damaged something or if i start putting 93 octane will the codes clear up? i have a 2002 disco 2 with 96k miles
Old Nov 30, 2008 | 07:12 PM
Default RE: check engine light
No switching gas will not clear things out.
You need a tune up, plugs and wires.
That will take care of your mis fire codes and your O2 codes as well.
Start running 93 octane and use nothing less than 91 octane.
www.atlanticbritish.com, make sure that you use ONLY the Magnecor plug wires, if you use anything else you will be doing it again in a month.
Old Nov 30, 2008 | 08:21 PM
Felipe,
How many miles on your truck?
Low octance can with time cause you some grief but as already mentioned, if you are at 60,000 miles or more it is time for a major service.
FlyingZebra34
Feb 22, 2014 05:39 PM
RoverZebra
Dec 8, 2012 04:27 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
