check engine light 95 d1
Old Oct 7, 2008 | 02:39 PM
greenlander's Avatar
6th Gear
Default check engine light 95 d1
i was hoping someone could let me know some things to check or parts to change before having it looked at...
i read a couple of other posts and im hoping it could be the gas cap. i looked and sure enough it wasn't on right
thanks ,neil
Old Oct 7, 2008 | 02:44 PM
6th Gear
Default RE: check engine light 95 d1
never mind ill goto auto zone and get codes first thanks for your help
Old Oct 7, 2008 | 03:10 PM
ptschram's Avatar
Autozone will be no help to you with a '95. There is a box beneath the right seat with a two digit display. Read the code there.
Old Oct 7, 2008 | 03:11 PM
AutoZone cannot read the trouble codes on a 1995, OBDII didnt come out until 1996.
Old Oct 18, 2008 | 03:36 PM
6th Gear
thank you for the reply as for the box i think ive found it it says rAnge rover on board diagnostic display it has a sticker with a bar code but no 2 digit # that i can find also under there is a relay and another heat finned box do you need to remove it or have the car on to get the #
thanks agian neil
FlyingZebra34
Feb 22, 2014 05:39 PM
RoverZebra
Dec 8, 2012 04:27 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
