check engine light after Sea Foam
Old Jan 9, 2007 | 11:25 AM
  #21
Default RE: check engine light after Sea Foam
Thanks Scott, actually I am an old retired kid amoung you guys, heart issues knocked me out of work last year and know I just cruze around the different Rover forums and see what I can stir up.
Take care,
Mike
Old Jan 9, 2007 | 02:54 PM
  #22
Old School's Avatar
Will do, Mike. BTW, I dropped my Disco off this AM at my local dealer with the expectation they will figure out the leak. When I asked why their proposed fix of installing a new sunroof did not fix the error back in April, they quickly turned it back on me and asked why is it January and I am claiming the same problem. Thank God their system shows the car was in their twice since May on the same matter. I told him that I suspect the drain tubes are plugged or broken. I hope they figure this out.
Regarding the MAFS issue, I received the FedEx confirmation from Tony and it seems my items will be here on the 12th. Will the light go off by itself or will I need to get someone to turn it off?
Old Jan 9, 2007 | 05:14 PM
  #23
You will need to have the codes cleared by a local auto parts store after installing the new MAF, other then that you will be set.
mike
Old Feb 7, 2007 | 07:30 PM
  #24
Knoxrover's Avatar
4wd High
Uhm..just a quick question on the "big blue brittish kitty" lol...?
Old Feb 8, 2007 | 02:24 AM
  #25
johnnybob06's Avatar
Where can you get this famous Seafoam??
Thanks!
John-Robert
Old Feb 8, 2007 | 10:23 AM
  #26
Most auto part stores have it, Napa is a big supplier of it in most areas.
If you decide you want to clean up the old engine, buy 2 cans of SeaFoam and shout when you are ready to use it, I'll be glad to walk you thru the process.
Mike
Old Feb 8, 2007 | 11:29 AM
  #27
DiscoIIMurf's Avatar
You can now get Seafoam in a 1 gallon can! Here in Minnesota, Fleetfarm carries it for about $38.
I sucked it into my Camry intake last night until the exhaust came out clean. Lots of black sooty smoke for about 10 minutes though.
I should be able to tap into that gallon can over and over again for different vehicles including the Disco.
Old Feb 8, 2007 | 03:32 PM
  #28
bigugly82's Avatar
Knox
She's blue, british, and now (after Foaming) purrs like a kitty. I know, bad line; but it worked great.
-Ugly
Old Feb 8, 2007 | 03:46 PM
  #29
Hopefully this weekend I will go out and SeaFoam the crap outta my truck! hahah... I'll let ya know!
John-Robert
Old Feb 9, 2007 | 04:54 PM
  #30
piotrsuw's Avatar
After reading this thread I am considering SeaFoaming my engine. However, it seems to me like sending all these deposits out of you engine and through your catalitic converters could mean a new set of catalitic converters. Damage to the cats is usually not apparent but if they are not "firing" anymore it will result in a CEL coming on. They may also get partially plugged in which case you might feel less top-end power. Has anyone experiencedemissions problemsafter the SeaFoam treatment??
Piotr
