Checking ECU Grounds
Old Nov 17, 2021 | 11:39 AM
Zdug4x4's Avatar
7th Gear
Default Checking ECU Grounds
Does anyone have a run down of how to check your ECU ground connections I have ohmed connector C0634 to pins 4, 5, and 6 with battery negative off and they are good but didn’t get anything from the other various connectors grounds. Can I ohm check with ecu disconnected and battery connected?
Old Nov 18, 2021 | 04:47 PM
Sandman614's Avatar
What issue are you working on? Checking for resistance/continuity is usually done with the circuit not connected to power.
Side note do you have the RAVE electrical circuit diagram? Super handy with all the connectors/pins labeled.
Moretti
Mar 29, 2024 02:03 AM
dmenchaca1966
Nov 9, 2021 08:02 AM
Hanomag
Mar 7, 2015 07:02 AM
Extinct
Apr 24, 2013 07:21 PM
JRdisco1
Aug 25, 2005 03:07 PM
