Checking Transfer Case Oil
Old Mar 31, 2014 | 05:55 PM
jalodge's Avatar
Default Checking Transfer Case Oil
Is there a trick to getting the fill plug out of the transfer case? There is a wire wrapped in foil going right under it and I can't use an extension because the e-brake drum is in the way.
Old Mar 31, 2014 | 06:00 PM
dusty1's Avatar
should be able to get between plug and the cable, i also have yanked mine down and got over it
Old Mar 31, 2014 | 09:03 PM
jfall's Avatar
You need a 1/2 inch extension and a swivel and a lot of patience.
That's how I did it.
If you like to swear then this is the time to practice the art.
Old Mar 31, 2014 | 09:06 PM
jalodge's Avatar
I tried both but it might be because there is a lot of dirt and oil inside the plug. I will try cleaning it out and see what happens.
Old Mar 31, 2014 | 10:11 PM
FlyingZebra34's Avatar
If you remove the cross beam on the frame it'll make life easier, using a 4" extension helps.
After you do it 100 times it's easy as can be.
Old Apr 1, 2014 | 06:00 AM
drowssap's Avatar
you can reach right over the top of the cross member with a 12 inch extension with a u-joint on the end.
Old Apr 1, 2014 | 08:07 AM
Jared9220's Avatar
I just use a 1/2" ratchet, no extension, no swivel. I go up over the exhaust and put the ratchet in between the parking brake cable and the T-case. It works best and is really easy once you do it the first time and figure it out.
Checking Transfer Case Oil-100_2456.jpgChecking Transfer Case Oil-100_2458.jpg
DiscoRover007
Jun 26, 2015 12:21 PM
CandiMan
Aug 18, 2008 08:51 AM
Td5
Sep 1, 2006 05:01 PM
disco12
Mar 6, 2006 05:02 AM
chrisusvi
Feb 25, 2006 04:19 PM
