Chirping only while accelerating???
Old 06-18-2020, 02:28 PM
DBLDisco's Avatar
Checked the front drive shaft it appears to be factory with snap rings and no visible grease buttons.
Old 06-18-2020, 02:33 PM
DBLDisco's Avatar
It looks like this one
Old 06-18-2020, 04:12 PM
boston4's Avatar
Try grabbing it to check for play in the u-joints. I suspect you'll hear some bad noises - should be nice and tight.
Old 06-18-2020, 07:57 PM
merebel's Avatar
mine was tight with no play at all but the unjoint cap was cracked at the base. I had a bad vibration. Replaced with a lucky 8 one and everything was fine after that.
i didn’t see the bad cap until old shaft removed and then I could feel it and see the bad cap
piperff (06-19-2020)
Old 06-19-2020, 05:27 PM
Extinct's Avatar
Received 1,462 Likes on 1,038 Posts
Agreed, the feel inspection is only valid with it out of the truck - 8 bolts.
Steven Gray
Range Rover L322 (3rd Gen)
03-09-2022 11:29 AM
landroverdude
03-12-2020 05:12 AM
desmd99
06-24-2014 11:01 AM
KernowDiscovery
05-30-2014 10:44 PM
pickps
05-14-2007 12:42 PM
Quick Reply: Chirping only while accelerating???
